The Missing Digit
Old Jul 23, 2022 | 10:44 AM
Coventrywood's Avatar
Question The Missing Digit
After not posting any unanswerable questions for a few days, I'm back!
I sent my injectors off to be rehabbed & tested. Half failed irrevocably, cannot be repaired.
Turns out they're as rare as hens teeth. (Whoopee!)
I took a photo of one as a reference, didn't realize I have a clear picture of a number who's last digit is obscured. And the last three digits
028 150 02X
are all important!
Anyone have the full number for this 'widebodied' injector?
Anyone have a likely source for these?
Thanks!
Old Jul 23, 2022 | 11:16 AM
motorcarman's Avatar
Looks like Bosch 0280150025
Old Jul 23, 2022 | 07:06 PM
Jose's Avatar
are the Series 2 XJ12 cylinder injectors different from XJ6 Series 3 injectors ??
Old Jul 23, 2022 | 09:05 PM
Wink Digit - ally altered
OK, thanks for the quick responses!
Determined my far-away FI are part # 028 150 023. (Sure didn't LOOK like a 3).
Different numbers can be different performance (flow rates), or simply different method of top hose attachment. Barb vs clamp.
Haven't discovered why some early Jag injectors have a wide collar, most usually don't. A heat sink to protect FI coil in a hot V12 valley?
If your vehicle has the widebody FI, your injector retention clamp has a larger hole. Won't clamp standard size injector.
Obi
Feb 26, 2022 01:37 PM
Mykk
Oct 14, 2020 10:09 PM
Qvhk
Feb 28, 2017 08:18 AM
prestone08
May 4, 2013 08:30 PM
calvindoesntknow
Jul 27, 2012 06:15 AM
