missing fuel?
Old Jun 30, 2014 | 04:51 AM
Mad Matt's Avatar
Cool missing fuel?
hi guys thanks for all our imput.
I noticed that my left tank is completely dry despit being filled and last week and i was using the right all week. i did smell fuel for the first couple of days but put it down to the tuning issues i was having now fixed. so a possible leak. what are the most common thing to check. boot clean.
Old Jun 30, 2014 | 04:59 AM
o1xjr's Avatar
Mine was leaking from the drain plug at the bottom of the tank. There are two,one screws into the other. On mine the larger one was leaking so I replaced the seal(rubber washer) I went to the local mower shop and bought a sheet of fuel resistant rubber and cut my own. Five bucks,and now I have enough spare to last a lifetime.
I removed the tank and looked for rust holes before I found this,
My suggestion is start there first,then put in a few litres and see what happens.
Did I notice you live on rural property from your pics of "lady J",if so being parked outside you may not notice a fuel leak soaking into the ground. Put a sheet of tin or plywood under the tank so you can see any leakage.
Old Jun 30, 2014 | 11:57 PM
Mad Matt's Avatar
Yeah we are rural and not concrete slab the spare is sitting on that with no wheels. Thanks I will check that first up and go from there. I will change the seal just to make sure anyway
Old Jul 1, 2014 | 10:07 AM
moronthethrottle's Avatar
I've been using the gasket for the distributor of a 350 Chevy for years. Still no leaks. Was supposed to be just a temporary fix to get by (was all I had in my shop at the time), but 8 years later it is still holding fast.
Old Jul 3, 2014 | 07:53 PM
Mad Matt's Avatar
Well the tank had fuel in it but ended up over me I think the pick pipe may have been blocked. Checked the filter replaced the plug but fuel in and ok. Go figure. Next problem is the fuel gauge on the right tank.
dsnyder586
Dec 29, 2024 07:39 PM
Razor
Aug 28, 2019 08:34 PM
ccfulton
Sep 20, 2015 05:15 PM
lovemyjag78
Sep 14, 2015 07:42 PM
deanh
Sep 6, 2015 08:20 PM
