My Jag 87 XJ6 no start
Old Apr 18, 2015 | 11:49 PM
Bones's Avatar
Default My Jag 87 XJ6 no start
I had the head gasket changed, drove my Jag 24 miles, it ran great, until it died. we replaced the dist. pick-up, spark plugs, fuel switch over valve and MAF, it will start now eventually but dies right away, it will not start again until it sits a while. Does anyone have any clues to what may be wrong ?
Old Apr 19, 2015 | 02:31 AM
Welcome to the forum Bones,
I've moved your question from General Tech Help to XJ40 forum. Members here with the same model will be able to help.
Old Apr 19, 2015 | 08:53 AM
Doug's Avatar
This question belongs in the "Series III XJ6/XJ12" section
Old Apr 19, 2015 | 09:00 AM
Doug's Avatar
The 'could be' list is long.
First, on general principle.....
At the rear of the water rail there's a bundle of ground wires. Did they *all* get securely reattached after replacing the head gasket?
Next....
'Starts but dies right away' suggests that the fuel pump isn't staying running. Check connections at the relays on the firewall. If they look OK, hot wire the pump circuit so the pump runs constantly and see if anything changes. We can help if you don't know how to bypass the pump circuit.
Is the ducting from the air flow meter to the throttle body tight and intact?
Is the connector at the fuel injection coolant temp sensor undamaged and corrosion free?
Is there any evidence of gross over-fueling? Wet plugs, black smoke?
Post back !
Old Apr 19, 2015 | 11:01 AM
Don B's Avatar
Bones,
Welcome to the Jaguar Forums! I'm sorry you're having trouble with your Series III XJ6.
I have moved your thread from the forum for the XJ40 to the forum for the XJ6 Series I, II & III cars. As Doug has mentioned, this is the correct forum for topics concerning your model.
Cheers,
Don
Old Apr 19, 2015 | 11:38 AM
Bones's Avatar
Next....
Post back !
Doug, Thank you, I haven't tried checking the fuel pump, I will do that Tuesday.
1100me
Aug 27, 2020 11:37 PM
rusty37
Jun 7, 2016 04:43 PM
RaceDiagnostics
Dec 11, 2015 10:12 AM
1964Daimler
Sep 2, 2015 11:41 PM
pnwrs2000
Aug 28, 2015 09:31 AM
