Need more info
Need more info
Hey guys, I'm currently doing a 350 swap in my xj6 series 3. And I was wondering if I'll have to change the drive shaft and/or the rear axle. I've been searching forums and websites to try to find the information I need but can't seem to find it. So I was wondering if someone could help me with their knowledge. Thanks in advance.
BigNorm
BigNorm
If you keep the stock 2-piece drive shaft, my preference, the front shaft will more than likely need to be shortened or lengthened. It will depend on where the engine gets positioned and the length of the transmission you use. You will have to mount the engine/trans in place before an accurate measurement can be done. In any case, the front drive shaft yoke will need to be changed to match the output shaft of the transmission. The IRS doesn't need any change of position.
Dave
Dave
BigNorm (04-18-2023)
Received 10,810 Likes
The diff itself is very robust. I’ll toss out a number and say it’s safe for 400hp. Opinions may vary on that.
The rubber mountings for the rear subframe will be the weak spot if you have a hot V8. Should be Ok for mild versions…..assuming they’re in good shape to begin with.
The following 2 users liked this post by Doug:
BigNorm (04-19-2023),
Greg in France (04-19-2023)
The rear end will be fine with anything a 350 can throw at it.
The following 2 users liked this post by Jagboi64:
It's virtually identical to the rear differentials in 1/2 ton pickups of 30 years ago as well as the front differentials of 3/4 ton pickups (Dana 44). As said, plenty stout unless you are the type that can demolish an anvil with a rubber hammer. As Doug has advised, the 4 rubber sub-frame mounts will be the weak point if you're going to thrash it.
Dave
Dave
The following 3 users liked this post by LT1 jaguar:
jacobxj6series1
09-21-2022 09:23 AM
Socal
11-06-2014 04:29 PM
