New to forum
Old Feb 5, 2024 | 10:59 AM
Nylonpunk's Avatar
Originally Posted by 1983turbojaguarxj6
It could be a number of things, what’s your air/fuel ratio? Are the turbo’s sized correctly? Being twin turbo, it should be efficient and spool pretty quick.
Forgot to answer my AFR is 11.5 at idle and 11.75 at cruise. Somewhere between at WOT
Old Feb 5, 2024 | 11:01 AM
Nylonpunk's Avatar
Originally Posted by LT1 jaguar
The installation of Nylonpunk will need more carb attention (modification) and fuel/air tuning than an engine with fuel injection.
Dave
Well noted.
I think I need a pro now. Anyone have any good ones in Northeast NJ?
LMK, Thank you for your replys!
Old Feb 6, 2024 | 04:19 AM
LT1 jaguar's Avatar
Active Streak: 60 Days
Here is a useful article from Holley on tuning and function of the power valve. Your A/F is way to rich at idle and highway cruise and you should check your vacuum at idle and cruise. How much did you drill out the restrictor holes behind the power valve? An 850 DP is a pretty big carb for a street SBC even with turbo's. You mention your A/F ratio is about the same at WOT as at idle/cruise. 11.5 is good for WOT, but never for idle or light throttle cruise, find out why its running rich and from where.
https://www.holley.com/blog/post/how...ey_carburetor/
Dave
Old Feb 7, 2024 | 10:49 AM
Excalibur2012's Avatar
Default Forums
Join Jag Lovers also ! Both have value .
Stubbornbxstard
May 24, 2022 05:25 PM
Mad Matt
Jun 18, 2014 04:30 AM
dcburton78
Nov 20, 2013 02:38 AM
denraden1
Sep 11, 2012 03:01 PM
jjcarr
Aug 26, 2012 08:02 PM
