new jag owner HELP??
Old Oct 17, 2011 | 04:39 PM
1987jagman13's Avatar
Default new jag owner HELP??
hey guy im trying to get to the harmonic ballencer and cant figure out how the fan comes off
anybody know???
p.s picked up a 1987 jaguar xj6 112000 mi possibe engine seized everything eslse is perfect
300 bucks
Old Oct 17, 2011 | 05:01 PM
Doug's Avatar
Where in the process are you stuck, exactly?
The fan is bolted to the fan clutch, which is mounted to the water pump on four studs. It's really just like an old style USA V8 fan arrangement...except getting the nuts of the studs requires a bit more dexterity
Old Oct 17, 2011 | 05:12 PM
o ok i thought there was a big nut on the end of it?? i did think those nuts would come all the way off. ill give it a shot thanks
Old Oct 17, 2011 | 05:38 PM
ok got the nuts part way off and i tried sliding the it off the water pump a little bit and wouldnt budge
Old Oct 17, 2011 | 06:24 PM
sneal46's Avatar
You may want to take the whole assembly off the front of the water pump. 1 1/4 wrench (20 at Autozone) and whack it with a rubber mallet a few times. Mine came right off. Put a little pressure on the belt to hold tension if it sticks. Then remove fan on the bench.
Old Oct 17, 2011 | 06:27 PM
yep thanks guys got it off and and tryed turning the engine from the crank and shes defienty seized up.... anybody needs parts let me know
Old Oct 18, 2011 | 04:48 PM
Fraser Mitchell's Avatar
Engine swap time, then. As an '87, is your car an XJ6 Series 3 (al curvy), or the later XJ6 (XJ40 model with squared-off style body from 1986 here in the UK) ?
I can't see it being economical to rebuild the seized engine, better to find another one which you can at least turn over, even if it needs some work. If it was me, I would at least take the head off the replacement engine, and probably the sump for inspection.
Forcedair1
Sep 8, 2025 01:57 PM
allenman85
May 10, 2021 03:11 PM
FeralJag
Jan 11, 2016 05:07 PM
Chet Ramnarain (bozzner)
Sep 3, 2015 07:47 PM
Sep 3, 2015 12:21 PM
