New window switches installed
Old Oct 16, 2011 | 09:50 PM
86JAGVP's Avatar
Default New window switches installed
I ordered and installed all new window switches. WOW! Amazing improvement. I'm really having a great time working on this car.
Old Oct 17, 2011 | 02:31 PM
Fraser Mitchell's Avatar
Right on ! Best to start with the little jobs first, and in next to no time, you'll be ready for suspension rebuilds etc.
Old Oct 21, 2011 | 07:12 AM
JagLoverT's Avatar
Default New Window Switches
To 86JAGVP
Did your old switches work at all? Your comment on what an improvement made me think maybe I need new window switches because my power windows are very slow in both directions.
Old Oct 21, 2011 | 07:43 AM
Doug's Avatar
If you like to tinker you can gently pry the switch(es) open and clean the contacts.
Another common cause of slow windows is dry felt run channels....some silcone spray will help loosen things up.
Also, the window regulators themselves are often stiff from lack of exercise (especially the rear ones) and benefit from a thorough spraying of aerosol penetrating solvent to loosen the joints and soften the dried grease...followed by a generous slathering of aerosol lubricant.
While the trim panels are off you can give the door latch mechanisms the same treatment.
Old Oct 22, 2011 | 08:41 AM
86JAGVP's Avatar
Thanks Doug. When we first got the car the windows didn't work at all. I replaced two motors, reconditioned the regulators, and did what you described in cleaning the switch contacts. They were pretty worn out, but it got them to work for a few months. It took a lot of work to get the windows back to par but it was one of my favorite projects.
99xk8guy
Sep 29, 2025 10:51 PM
aholbro1
Dec 29, 2024 06:46 PM
kevinl
Oct 31, 2019 06:15 PM
GordoCatCar
Jan 2, 2017 01:10 PM
fingers
General Tech Help
Oct 21, 2015 02:02 AM
