New XJ coupe project - 2015
Old Dec 29, 2017 | 07:31 PM
  #141
Rustyxjc's Avatar
Just one more improvement I'm gonna copy!
thanks for the detailed answer !
Rusty
Old Dec 30, 2017 | 03:26 PM
  #142
ronbros's Avatar
good job!
my cross brace from body support side to side and angled back to the cowl itself , it did help with cowl shake quite a bit !
Old Dec 30, 2017 | 06:11 PM
  #143
icsamerica's Avatar
Originally Posted by ronbros
good job!
I like that. Does it fit under a stock hood? I'd like to know so perhaps I can fab one up the the 6.0 T56 Xjs.
Old Dec 31, 2017 | 05:04 PM
  #144
ronbros's Avatar
it does fit under the early XJS hood/bonnet, nothing touches!
Old Jan 4, 2018 | 08:23 AM
  #145
Roger Mabry's Avatar
Default How to lower the front spring pan
This information is from another post.. I could not find that post but I think it was from icsamerica. I am about ready to do this task myself as my car is too high due to the SBC and the use of lots of aluminum engines pieces and putting the engine back 1.25 inches.
Item parts list and results are included...will not lower your car 2 inches.. but the correct way to get about one inch.
If you have many spacers under the springs you could get more lowering by removing them... be sure to do it correctly or you can get hurt!
Or you could order and replace the front springs with proper replacements for use with a engine change...
Attached Thumbnails New XJ coupe project - 2015-20170115_170055_1__d03eb9776e2860d7f3f0a12f611b941481753694.jpg
Old Jan 4, 2018 | 01:05 PM
  #146
Rustyxjc's Avatar
I Just completely disassembled my front end and found 4 of these in with each spring. I am thinking of deleting 2 from each side any thoughts?
Rusty
Old Jan 4, 2018 | 01:29 PM
  #147
I saved this from a prior Forum article:
"There are nylon (I think that's what they are made of) spacer rings between the spring and upper and/or lower spring seats. Supposedly the number of
them vary, depending on the spring color code, anywhere from a minimum of two and a max of four. For example, my cat has four on each side, two above
and two below the spring.
Depending on whom you believe, each spacer (1/8" thick) changes ride height at a 2.5 or 5.0 to 1 ratio. I think it is closer to 5:1 than 2.5:1, because
my ride height increased over an inch when we reinstalled all four spacers (had just two on each side when we changed springs during conversion)."
I wish I had spacers to remove... I cannot see any on top or on the bottom on either side....
Old Jan 4, 2018 | 02:03 PM
  #148
Rustyxjc's Avatar
Thanks for the quote!
I think Ill delete 2 on each side. I need to look up the weight difference between an xk engine and a AJ16s!
Rusty
Old Jan 5, 2018 | 06:50 AM
  #149
slofut's Avatar
ICS, are you not running a MAF sensor?
Old Jan 5, 2018 | 07:45 AM
  #150
icsamerica's Avatar
No MAF... the ECM is speed density with a rather large and expanded VE table. I had run a MAF on an earlier convert and hit a few road blocks. Primarily, the MAF limited air cleaner and air intake tract shape and maximum flow. Also the SD ECM is simpler has more options that I needed like DIS and Launch control which I have not used yet. I really do love the early GM MAF based system but as a practical matter I got better drive-ability and much higher performance from the later GM speed density setup. The SD setup also has about 20% fewer components.
Old Mar 10, 2018 | 05:45 AM
  #151
blot3.8's Avatar
Coupe looks ace Enjoyed reading this, I will be following your latest coupe build, Cheers.
Old Jul 12, 2018 | 12:51 PM
  #152
icsamerica's Avatar
Update on the 2015 Coupe....New wheels, and Michelin Tires and DB7 GT brakes and suspension. Dropped off some metal at the recycle center, 3800LBS. More then I expected but great considering all the mods. I'd like to get it down to 3650... I have some ideas.
Old Jul 12, 2018 | 05:49 PM
  #153
Rustyxjc's Avatar
Wow, big difference. They suit the car better than the last ones. Makes it look more sophisticated somehow. I cant tell for sure but did you adjust the stance the car seems to be "Leaping" ever so slightly or it is perfectly level. Either way, it looks perfect! What are the details please Rim/ Tire size?
Rusty
Old Jul 12, 2018 | 06:53 PM
  #154
andys-GR's Avatar
She looks beautiful, I lift a glass to a job (very) well done.
Thanks for sharing
Old Jul 13, 2018 | 07:08 AM
  #155
sanchez's Avatar
After I did my Chevy conversion, the front was sitting too high. From the floor to the center of the headlamp the measurement was 25 3/4 inches.
I then purchased a pair of front springs that I was told was for a Jag with a Chevy conversion and that it would return the car to it original ride height.
After installation of the new springs with no nylon spacers (recommended) the ride height increased from 27 5/8 to 29 inches. Apparently the springs were incorrect.
I removed the new springs and re-installed the old springs with the nylon spacers, and added 3/8 spacers between the spring pan and lower control arm.
After driving the car around for a couple of months the front of the car settled and was now lower than the rear and the car had a diving stance.
Not happy with the way the stance looked, I disassembled the front again.
I removed the spacers I had added at the spring pan and removed the nylon spacers (3 on each side) and reassembled everything.
Now with the spacers removed and the car driven around for a while, the height measurement from the floor the the center of the headlamp now sits at 23 inches and the car is level
Old Jul 13, 2018 | 04:23 PM
  #156
This time the Vicious, Nasty scripting of this place has even crashed Windows!
TWICE!!
Second time, my "Auto-'saved" content was Not recovered!
In case the smiley didn't make it, it was the Ranting guy blowing his top!
Insert me in place of him!
BAH!
Old Jul 13, 2018 | 08:30 PM
  #157
alynmurray's Avatar
Outstanding !! Really nice coupe . Great workmanship.
How did you solve the handbrake cabling modification with the outboard rear discs?
I have the vented rotor outboard brake set up from 2001 XJ8... about ready to install - if I ever get time....
Old Jul 14, 2018 | 07:25 AM
  #158
Woznaldo's Avatar
Love the new wheels. What size and offset are they? What tyres are you now running?
Havd you got a 3/4 view to better see how the wheels sit in the arches/fenders?
Woz
Old Jul 18, 2018 | 10:54 AM
  #159
After a pitched battle between my computer and this forum (in which I have at last prevailed), I'm again able to post pictures without this place crashing me back to the stone age.
As I was trying to say previously:
The more I see posts like this the more grateful I am that Nix came to me with springs "adjusted" or whatever they did, and fiven a ride height I like.
22 inches from the floor to the center of the outer headlight.
Rocker panels are level..
With this low profile and center of mass, she hugs the road and corners like she's on rails.
I have to be careful with some of the more aggressive speed bumps and harsh driveways, but those are rare in my world, and I do So enjoy when someone comes around a corner, sees this low-slung BLACK cat ready to pounce, and they do a double take.
And that makes it all worth any slight inconvenience we might encounter.
PS. It's good to be back!
Old Jul 18, 2018 | 12:42 PM
  #160
sanchez's Avatar
@LnrB: Nice! All you need now are some 7" headlamps.
