Next project…….
Old Dec 18, 2021 | 02:51 PM
Darrenmb's Avatar
Veteran: Navy
Default Next project…….
About to start prepping for the next project and I haven’t even started the one before it yet!!! The week after Christmas is when I will be swapping out the gears to 3:73s and the next project will be well underway ( but in someone else’s hands to begin with)
I have been scouring eBay and classified ads on the lt1 forums, and have scored a spare set of heads ( aluminium) and and Intake manifold, just got done reboxing them back up to send them to Texas to Elliot port works!!!! Am I going overboard? Of course I am! Only getting the le1 package so
not going crazy! Attached are the pics
befoare being shipped, more
to follow when I get it all
back!!!
Old Dec 18, 2021 | 04:48 PM
Yellow series3's Avatar
You only go around once in life so you might as well go overboard.
Jeff
Old Dec 18, 2021 | 07:10 PM
Good Job, Darren!
I agree with Jeff! Go For It!
Old Dec 18, 2021 | 11:29 PM
LT1 jaguar's Avatar
Active Streak: 60 Days
Are you going to upgrade your cam, Darren? The LE1 Elliot heads come with a lot of spring pressure, are you going racing? Every source I've come across agrees that the iron head flows better than the aluminum version. I hope your upgrade works well for you, let use know what the "seat of your pants" tells you. I'm interested to hear how your ring/pinion swap turns out also.
Dave
Old Dec 19, 2021 | 06:50 AM
Darrenmb's Avatar
Veteran: Navy
While talking to Lloyd he said I would
Be ok with my lt4 hotcam that’s currently installed, ideally he would do a custom grind, but cam cores are hard to get right now. There are
lots of lt1 s out there running the le1 and hotcam, it’s a decent combination, but does leave some power on the table! I’m ok with that, he has recommended adding 36lb injectors and a 58mm throttle body , as the intake will be opened up as well!!
i will definitely post on what difference the gears make!!!
keep watching this space!
zach05855
Jan 28, 2023 07:41 PM
rocketa9x
25
May 20, 2021 11:47 AM
Joel Brown
Jan 4, 2021 08:38 AM
zach05855
Jan 8, 2016 03:04 AM
super_jag
Exterior
Apr 20, 2009 11:31 AM
