Not start series 2
Old Feb 7, 2022 | 08:02 PM
Geo1234's Avatar
Default Not start series 2
Hi, i am new owner of xj6 series 2 1978. I buy this car a month ago and its start and running but it make backfire. I decided to make a compession test (dry and wet), i remove all the spurks and the wires. I didnt disconnect the fuel pumb during the test. When i finish the test i put back the wires with wrong firing order and the car didnt start. Then next day i put the wire correct and change the spurks but stil dont start and there is also fuel leak from ezhaust and at AED pipe when i try to start.
Does i made damage?
What i can do to solve the problem?
Old Feb 8, 2022 | 07:26 AM
Welcome to the Forums.
Please do an Intro in the New Members Area when time permits.
You have seriously flooded the beast.
Number the spark plug leads, REMEMBER #1 is at the REAR of that engine.
Remove the spark plugs.
Allow it to dry out, maybe a day or 2, depending on the weather wherever it is you call home.
Then refit the sparkers, and the leads, and see what happens.
These a basic simple engines, but flooding them is simply a time consuming thing to cure. It takes as long as it takes.
Down here we call that time "Beer O'Clock".
Old Feb 10, 2022 | 01:04 PM
Geo1234's Avatar
Many thanks for your prompt reply. I have removed the sparks and leave it for three days. Then, I applied correctly the wires and the car started immediately. You were absolutely right, thank you so much.
Does anyone know whether there is an online mannual available for this car?
Daf11e
Dec 7, 2020 01:50 PM
Braydon Deffinger
Sep 5, 2020 11:31 AM
Mr. Mohr
Jan 9, 2018 01:29 PM
bob peers
Feb 29, 2016 10:59 AM
mickvic
Feb 11, 2013 06:06 PM
