Oil pressure
Old Jan 30, 2015 | 02:12 AM
ahunt4's Avatar
Default Oil pressure
After getting a oil change, I noticed the oil pressure stays a little higher than 40. What should I check for this. I been always using full synthetic. Where are all the electrical wires that control the sending unit and everything that works with the oil that I could check as far as electricity and everything else that could cause the pressure to slightly rise.
Old Jan 30, 2015 | 06:12 AM
Doug's Avatar
I don't see a problem with the pressure being a little over 40 psi.
The sending unit and wire for the gauge is on the right side of the engine near the oil filter. There's a small oil pressure *switch* for the warning light and a larger unit.....sorta bell shaped or dome shaped....for the gauge.
Old Feb 7, 2015 | 09:07 AM
sneal46's Avatar
My car runs about 50psi warm @ 75,000 mi. Sounds normal to me.
Old Feb 7, 2015 | 01:54 PM
Giovanni LiCalsi's Avatar
You can remove the oil pressure sending unit and screw in an analog pressure gauge to find the correct pressure reading.
Old Feb 7, 2015 | 02:23 PM
dansxj6's Avatar
With clean new oil i get 42psi at idle and 65 at speed
bamforp
Aug 14, 2024 05:36 PM
99xk8guy
May 28, 2024 09:36 PM
jerry_hoback
XJ40 ( XJ81 )
Sep 13, 2015 07:48 PM
mhamilton
Sep 12, 2015 03:21 PM
giandanielxk8
Sep 6, 2015 07:21 PM
