Only one engine is working fine
Old May 6, 2018 | 08:23 AM
fridolin12's Avatar
Default Only one engine is working fine
Hello!
I have a problem wirh my Jaguar XJ12 5,3 Serie III sometimes one half of the engine is not working probaly and the car has no power also in N or in D.
What should i check first? Has anybody some helps for me?
Many Thanks!
Old May 6, 2018 | 08:40 AM
Doug's Avatar
I've had this problem.
There's a strong chance that the wiring harness for the fuel injectors is failing, causing one bank of injectors to be inoperative.
Sometimes a 'jiggle test'of the harness will tell a story. Or use a 'noid light' to test the injectors and see if they're all working.
You can buy a new harness of make up your own
Wolff87
Jan 1, 2018 03:55 AM
PinnacleWax
Detailing / Car care
May 8, 2015 12:41 PM
juliovega914
Jun 2, 2014 11:21 PM
Walter1982
Sep 10, 2010 08:23 AM
sirpatrickhall
Sep 21, 2008 11:08 AM
