Part name???
Old Jun 3, 2011 | 06:25 AM
doghead08's Avatar
Default Part name???
I was in my trunk yesterday tidying up some wiring connections and noticed that the metal trap under behind the back seat/under the back window was rusting pretty bad. I took the bolts out and discovered that it is in horrible condition. Hoses were clogged up so im assuming water found its way to this area. What is the name/purpose of this thing and what do you think I need to do to ensure that water stays out....also it had 4 square openings covered by thin pieces of flapping metal...what is purpose of the metal (covers) they almost remind me of a doggie door at the bottom of a real door.
Old Jun 3, 2011 | 08:03 AM
Doug's Avatar
I don't know the official name but I call it a "plenum". It's actually part of the ventilation system. Air exits the cabin into the plenum, to be exhausted into the boot via the flaps....which are one-way operation so air can't come in.
If the foam edging rots away from the flaps they'll make a "cow bell" noise when you close the doors :-)
Old Jun 3, 2011 | 09:37 PM
doghead08's Avatar
Default i need to find a new one??
do you have any idea where i can get one ?
Old Jun 4, 2011 | 10:28 PM
Doug's Avatar
Try David Boger at everydayxj.com
Old Jun 22, 2011 | 10:37 PM
bbarcher's Avatar
Make sure you unclog the hoses. It is normal for water to get in there but it has to be able to drain. Do some rustproofing on the replacement part. Or you might be able to patch up the one you have if you take it out and have some new metal welded in to repair the rust.
Old Sep 26, 2011 | 09:05 PM
pdog2000's Avatar
i just took out my plenum all together and plugged up all the holes...just kept the drain hoses hooked to nothing in the trunk so air would get in...also plugged up all the exhaust holes on the trunk and rear seats...
Old Sep 26, 2011 | 09:14 PM
pdog2000's Avatar
also for reference see this thread
https://www.jaguarforums.com/forum/x...ed-pics-54438/
Scott B
Oct 24, 2015 01:29 PM
wardo5757
Sep 11, 2015 11:31 AM
jaggermang
Sep 8, 2015 07:07 PM
DAN L
Sep 8, 2015 07:21 AM
1100me
Sep 7, 2015 06:26 AM
