Passenger side door mirror
Old Oct 3, 2022 | 04:33 AM
o1xjr's Avatar
Originally Posted by Robert Laughton
I think RH mirrors were an option. At least they were for S1's.
That's why they are hard to find.
Rob
All S1’s had a right hand mirror in Australia,I bought a hard to find left mirror from David Boger near 9 years ago and never fitted it as it would probably be the only S1 in Australia with a left mirror.
you just get used to not having it.
Old Oct 3, 2022 | 08:04 AM
Excalibur2012's Avatar
Default Missing the point !
Yes...The world can supply a plethora of cheap door mirrors. The S1 & S2 have a specific design. Some of us want THAT mirror.
Old Oct 3, 2022 | 02:29 PM
Robert Wilkinson's Avatar
An often ignored point is that driver's side and passenger side mirrors often differ in the angle of their mounting to the car. So a RH (driver's) mirror in Oz is not necessarily the same as a RH (passenger) mirror in the US, home of my esteemed friend David Boger.
Old Oct 4, 2022 | 11:36 AM
Default RH
RH vs LH Drive ! NOTED ! Got NA Pax Mirror.
Old Oct 6, 2022 | 05:01 AM
o1xjr's Avatar
I had a mate hold it in place while I was in the car, played around with the mounting position and marked it out , sent the car off for some paint touch up and forgot to tell the beater about fitting the mirror, it’s still sitting in the tool box in the boot 9 years later.
Old Oct 6, 2022 | 06:23 AM
yachtmanbuttson's Avatar
Unfinished project #842. We all have them.
Old Apr 16, 2023 | 05:20 PM
Default RH Installation
Found an actual RH S2 mirror but it still has the adjustment cables for the remote attached. Toggle itself is missing. Not sure where to get parts to fix the toggle issue if it even can be fixed. I really don't need to make it remote, but what should I do. Could just secure & tuck the cable or cut it off. Would it stay adjusted if set by hand ? Thoughts or experience ?
Old Apr 20, 2023 | 11:12 AM
  #28
Gatucho's Avatar
Default Ser 2 coupe rh door mirror
I'm having the same issue. I have the rhs mirror with the adjustment, but I think it will not adjust enough to be of any use, so I'm going to take it apart and make it manual. I remember rhs mirrors were an option and trying to remember how to drive without one is nerve wracking!!!
Old Apr 21, 2023 | 04:07 PM
Default RIGHT !
Think we are on our own at this point. We each will find a solution & move on.
Old Apr 30, 2023 | 06:22 PM
  #30
xjtom's Avatar
Denis,
I'm in Sydney Australia obviously were are right hand drive but the solution could be the same, i have an XJ6 S2, wanted a left hand side (my passenger side) mirror, outrageously expensive here in Aus/ so i bout a L/H/D drivers side form the US to match mine....perfect fit, same mirror with all mechanical parts and less than 1/2 the price in Aus........soooooooooo maybe you could get the opposite from Aus, get our drivers side which is your passenger side..........just a thought..if you need any contacts i'm a member of the australian jaguar drivers club so know plenty suppliers.........
Old May 2, 2023 | 10:57 AM
  #31
Default Sourcing
Too late for me but excellent idea for others !
Originally Posted by xjtom
Denis,
Old May 4, 2023 | 11:31 AM
  #32
Gatucho's Avatar
Lightbulb Sticky notes
I found this in the Martin Robey catalouge;
I noticed yesterday whilst driving that its easier to look out towards the wing than turn your head to look out the door window. I'm not so sure I want to drill holes in my fender, granted ya gotta drill holes somewhere if ya want the second mirror...
Old May 4, 2023 | 11:32 AM
  #33
Gatucho's Avatar
Default Martin Robey catalouge
this image is in the sticky notes
Old May 5, 2023 | 07:28 AM
  #34
Default Backing Up
Hard to back into a garage without a side mirror. The sheetmetal is not sacred & small holes are easy to repair if you should error.
ronrowand
Jul 21, 2021 03:18 PM
Bob Hornby
Apr 30, 2021 05:59 AM
stremsjg
Aug 26, 2018 07:08 AM
pearlfisher
Feb 25, 2013 10:15 AM
monz87
Apr 1, 2010 06:05 AM
