Plate on aft end of 4.2 block
Old May 3, 2020 | 08:28 AM
yachtmanbuttson's Avatar
Default Plate on aft end of 4.2 block
Plate in aft end of 4.2 block on# C.27876
If I take this off, will all the coolant come flooding out?
Thanks, Bill
Old May 3, 2020 | 09:06 AM
YES
Old May 3, 2020 | 10:15 AM
Jose's Avatar
the block drain is on the side of the block, washer part no. C.2296 and then a bolt.
early XK engines had a faucet there.
Old May 3, 2020 | 10:34 AM
Thank you! I suspected an oil leak from around that gasket, and had 5 bolts removed (to change the gasket), when the coolant bolt of lightning hit me, That's when I decided to post the question. You helped me avoid ANOTHER stupid brain fart. Thank you!
luvinmyjagxf
Nov 20, 2017 10:00 AM
nasomi
Nov 18, 2016 10:37 AM
ez53436
Feb 22, 2014 08:48 PM
rianbechtold
May 2, 2010 03:51 PM
