Problem with Red Diode relay
Old 05-27-2022, 07:18 PM
Jean Pierre's Avatar
Default Problem with Red Diode relay
Hi Jag lovers! I have a 1986 XJ6 Sovereign. Love it. My red diode relay is damaged. I need to replace a diode inside. Anyone knows what size (resistance) diode goes inside the red relay? I noticed there are 4 diodes, two seems to be the same size and the others are different. . These red diode relay are hard to find and are expensive so O would like to fix it instead of buying a one. Please feel free to share your wisdom
Mkii250 (05-28-2022)
Old 05-28-2022, 06:19 AM
Robert Laughton's Avatar
Hi Jean,
I may have one. I'm near you in St Catharines.
I'm not sure which elay you need. Where is it located? What does it control?
Rob
Old 05-28-2022, 09:46 AM
Hi Rob thanks for reaching out. Do you have spare parts for Jaguar car? Let s connect. I am in Sudbury. JP
text me 647 519 5622
Old 05-28-2022, 12:49 PM
JagCad's Avatar
Received 2,399 Likes on 1,880 Posts
Perfect/ Source for a good one nearby!!! Better than seeking to fix a relay!!!
Not an elecrtic genius byt far. I think any small value dide would do just fine. t
Old 05-30-2022, 06:56 PM
Andy T.'s Avatar
The diode pack contains three blocking diodes and a resistor. The diodes are 1N4001 and are very cheap from component suppliers. You can also use 1N4002 1N4003…1N4007 as alternatives as the only difference is maximum voltage rating. 1N4001 is rated at 50V up to 1N4007 rated at 1000V
The resistor is 2.7 Ohms.
We should avoid using the word relay when referring to this diode pack…it just happens to be mounted in a relay-shaped package.
The following 2 users liked this post by Andy T.:
Coventrywood (06-01-2022), Doug (05-31-2022)
Old 05-31-2022, 01:50 AM
Jag-o-nomic's Avatar
Hi Jean Pierre,
I assume you are referring to the red 'Pektron' starter relay which is labelled perhaps confusingly according to Andy T as such by the Jaguar Factory Parts Catalogue? <Part DAC1861>
If Andy T is right about the guts of this then that is very helpful as those diode / relay packs are not easy to find in good condition now.
Cheers,
Nigel
Old 05-31-2022, 07:02 AM
Hi
I have looked at the broken one and was able to find the problem, is was on the weld on the small board. I simply put some on the joint and it is working fine.
thanks
69jaguar
E type ( XK-E )
11-23-2021 09:11 AM
rgp
06-27-2019 05:29 AM
MichelB
12-09-2017 10:26 AM
Doug
12-19-2015 01:22 PM
Bc xj
05-31-2014 08:18 PM
Quick Reply: Problem with Red Diode relay
