Radiator Removal SIII
Old Sep 3, 2019 | 06:10 AM
iramphal's Avatar
Question Radiator Removal SIII
Hi Guys/Gals,
Planning to remove and replace my Rad with a new shiny aluminium one. Anyone have a step by step procedure I can follow (that does not involve bonnet removal)?
Old Sep 3, 2019 | 06:40 AM
muttony's Avatar
There is one in the shop manual which you can download from the sticky page. Please do a write up when you do the work. Especially if you are going to do the thermostat and water pump while at it. Also if you can post the exact make and model of the new shiny one, it would help others, ie me, when I need to do it next year.
Mad Hatter's Avatar
I am not sure of the differences between my lumped S2 chevy radiator and your presumably stock S3.
However, I have pulled the radiator out of my car several times.
There are four small bolts holding the radiator upper support. Remove those, the hoses, and anything that is mounted to the radiator and it should just lift out.
If you want more room from the hood, you can remove a single small bolt that limits the hoods maximum travel.
This would allow the hood to go almost completely vertical, the springs should hold it there and you will have plenty of space to work around the radiator.
Old Sep 4, 2019 | 06:05 AM
iramphal's Avatar
The Rad is from Rockauto, made by Liland Global (China probably). Part number is 33AA. Cost $145 US ($175 Cad). Looks very well put together with clean welds. I hope it fits!
See link: https://www.rockauto.com/en/moreinfo...178096&jsn=923
Old Sep 4, 2019 | 06:46 AM
muttony's Avatar
Does it have the hole in the top right corner for the air intake snout?
Old Sep 5, 2019 | 06:43 AM
iramphal's Avatar
If you look at the picture in the link, there is an angled plate in the upper right side that will accommodate the intake snout, so I believe it will all fit together.
Clayxj
Apr 13, 2018 03:25 AM
new mexico
Jun 8, 2017 05:45 PM
JA0342787
May 8, 2014 09:24 AM
JA0342787
May 6, 2014 10:34 PM
bpeesy12
Dec 1, 2013 07:13 AM
