Relay problems help please
Old Sep 6, 2019 | 05:06 AM
Michael Parker's Avatar
Default Relay problems help please
I have an 1994 xj6 (xj40) sovereign 688366
I am having intermittent high mount stop lamp failure as well as engine cooling fan intermittently works( mostly doesn't work either one) had previously electrical issues with car car is stock minus exhuast and fuel pump(wide left trunk open in rain shorted out pump relay then fried the pump module is from 02 mercury sable as well as pump still has original evap loss flange and sending unit ) also only one blower motor blows until u put on defrost then both kick in on high only
Old Sep 6, 2019 | 05:09 AM
Default Help please
Need help locating the proper relays for replacement have extras of everything except dbc10009 I have that one ordered (have to tap relay for tag lights to illuminate after they're lit they stay lit
Old Sep 6, 2019 | 05:19 AM
Michael,
Welcome to the Forums.
Please do an Intro in the New Members Area when the beast is sorted.
Your XJ6 is known as an XJ40, as you know, and way more modern than the Series cars in here.
The XJ6 (XJ40) Tech Section is where you find answers related to your model.
Good luck.
Old Sep 6, 2019 | 05:20 AM
muttony's Avatar
Wrong forum Michael. Won't get help here because no one here knows your car. You should ask to have it moved to correct forum.
jjd
XJ40 ( XJ81 )
Oct 17, 2017 09:51 AM
yeldogt
Nov 27, 2015 06:50 PM
dtk
Aug 26, 2014 09:48 PM
tipn22
XJ40 ( XJ81 )
17
Oct 9, 2012 09:41 PM
daboss085
Mar 7, 2012 02:36 PM
