Radio suggestions
Old Nov 8, 2020 | 01:09 PM
denis4x4's Avatar
Default Radio suggestions
I currently have a Kraco cassette radio (probably $29.95 at Pep Boys back in the day) and looking to install a XM/Sirus with bluetooth and a remote control. Speakers are fine and I'm not **** when it comes to car audio.
Old Nov 9, 2020 | 10:09 AM
Darrenmb's Avatar
Veteran: Navy
Look into the pioneer mvh lineup, you can get them with no CD player, so the are only about 4 inches deep, plenty of room behind for wiring!! Mine is an older one, but still does, blue tooth, aux line in and a usb line in, hands free calling, etc, and if I’m. It mistaken you can buy the Sirius receiver to add to it! Sounds decent through the door speakers, and has preamp outs if you wanted to upgrade
Old Nov 9, 2020 | 09:17 PM
Jahmiata's Avatar
This one from RetroSound is what I'm saving for:
https://www.crutchfield.com/p_068LBB...e-Buttons.html
Jeff H.
Old Nov 10, 2020 | 07:29 AM
iramphal's Avatar
When I got my 85 XJ6 it came with original door speakers and an PO fitted afertmarket radio/CD unit. The sound may have been good for 1985, but was terrible in 2020.
I replaced the speakers with modern 4" Polk units. Better sound quality, but not good enough. I purchased this unit, the Kenwood-KSC-SW11-Compact-Enclosed-Subwoofer. It was easy to mount on standoffs under the front passenger seat and the control (wired) is on the inside of the dash glove box lid when it is opened.
It splices easily into the speaker wires as they leave the head unit and the whole installation is invisible. Once you set the various bass/bypass levels that suit your style, the unit will switch on with the head power and volume is controlled by the radio/head control.
The improvement in sound quality is just AMAZING! Thoroughly recommended.
Best mod I've made to the car as decent sound just enhances the experience of driving this machine, especially on long highway trips.
Old Nov 10, 2020 | 05:37 PM
Robert Laughton's Avatar
Nice one Ian!
What's your flavour - Jazz, Rock, ??
Rob
Old Nov 15, 2020 | 09:03 AM
Mkii250's Avatar
I am using one of these in my Series 3...like $160 and was able to set the screen to green to more or less match the trip computer.
And I'm using one of these under the passenger seat also, with 4-inch Alpine SPS 410 speakers in the doors. This set up is the best sounding system of my four vehicles. Plenty of fidelity at volume too...with the windows and sunroof open and 50mph still no problem hearing everything.
Old Nov 15, 2020 | 09:12 AM
Mkii250's Avatar
Ooh I have to say one more thing...after installing my new speakers and head unit, the sound would cut out if I turned the volume up over half way. Very annoying because it just wasn't loud enough. This head unit does draw way more power then the original one...eventually I thought to run a 18 Gauge power wire straight from the battery (through a fuse) to the head unit, instead of using the power wire in the car's harness. This fixed the problem. If you are installing yours, I'd suggest adding a heavier ground wire too while your'e in there.
SamtheSham
Sep 27, 2019 01:02 PM
rbr
Apr 6, 2015 10:03 AM
dougsjag
Nov 13, 2014 03:50 PM
Zulu
Jul 2, 2014 12:40 PM
2002XK8Orlando
Jul 18, 2010 01:29 AM
