Rear shock absorber installation trivia
Old Jan 8, 2021 | 09:06 PM
Doug's Avatar
Default Rear shock absorber installation trivia
A couple tidbits that might help someone installing rear shocks, especially a first timer.
Pic 1
It can be a little tricky to install the lower shaft that runs thru the control arm and thru the bottom eyes of both shocks. Take the shaft to your bench grinder and make a small bevel on the shoulder of the shaft. This allows it to pass into the shock eyes more easily
Pic 2
Inside the upper eye of each shock is this bushing, oft mentioned. Make sure to look for 'em and transfer them to your new shocks. If you don't install them you'll have one helluva rattle
Pic 3
The upper mounting bolts should be installed from the inboard side to the outboard side....so that the nuts are on the outside of the cage. Reversing this...only possible if the cage is out of the car....will mean that you can't get the bolts out once the cage is installed. Ask me how I know
Old Jan 9, 2021 | 01:44 AM
LT1 jaguar's Avatar
Active Streak: 60 Days
Tip #3 is well appreciated Doug, but alas, has come too late for me. Live and learn.
Dave
Old Jan 9, 2021 | 02:14 AM
GUILTY on all 3, no wonder I drink BEER.
Thanks Doug, well written.
Old Jan 9, 2021 | 07:59 AM
Robert Laughton's Avatar
Good stuff.
#3 reminds me of the steering rack bolts. They have to installed so that they can be removed when mounted to the car.
Rob
Old Jan 9, 2021 | 04:39 PM
Doug's Avatar
Dave
Well, it's not the end of the world, as I discovered. And would probably be a problem only on the rear-position shocks.....as the body-to-rear cage clearance is especially tight.
I slid the bolts out as far as possible and then took a Sawz-All to 'em !
Wayne Lea
Aug 6, 2020 11:38 AM
carsnplanes
Nov 29, 2018 08:20 AM
tjb909
Feb 22, 2017 02:53 PM
sbreeden
Jun 21, 2012 01:15 PM
guglielmo6160
Feb 16, 2009 03:08 PM
