Rear spring/schocks
Old Nov 14, 2019 | 02:05 PM
Rudy Mensink's Avatar
Default Rear spring/schocks
Hello Jagonauts;
In my Series 2 restauration I heve removed the rear bridge; the differential will be replaced by a 95 XJS differential and XJS hubs (with the ABS brakes). But now my question: the springs and schockabsorbers are 40 years old but seems not to be disfunctional. What is wisdom: change them all, or just let them be in place?
Greetz, Rudy
Old Nov 14, 2019 | 02:28 PM
yachtmanbuttson's Avatar
In my opinion, 40 year old shocks and springs should be replaced. Especially if you have the assembly out of the car. It's so much easier. Especially if you plan on keeping the car. And I'll assume you won't go to all this work just to sell it?
Old Nov 14, 2019 | 03:03 PM
The Mekon's Avatar
Rear shocks and springs are quite easy to remove with the entire rear suspension in the car. The original Jaguar shocks are a quality item, and should still perform almost as new if not leaking oil. Same for the rear springs. I have replaced all rear shocks, mainly because 2 were leaking, but I retained the original springs - now 47 years old. If your car sat well in the rear prior to dismantling, I see no reason to change.
Old Nov 14, 2019 | 09:39 PM
Doug's Avatar
IMO,
Springs: If the ride height is within spec, do not replace them. There's a good chance that the replacements will yield incorrect ride height.
Shocks: Personally, I'd replace them. Shocks degrade gradually. They may not be outright faulty or dysfunctional but I'd guess they're well past optimal
Old Nov 15, 2019 | 06:12 AM
Robert Laughton's Avatar
In my experience, the rear springs don't sag.
At one point I took 30 year old springs to a race shop to test the rate, and they were still stock at - I think - 200 pounds.
I think good new shocks are important, as these are heavy cars. If you can bounce the car around with your own weight, they need to be changed.
Good luck,
Rob
Old Nov 15, 2019 | 07:50 AM
Good luck,
Rob
Thanks to all , I gonna change the shocks since the springs seems n good order. And I replace the rubbers, oilseals,bearings,etc. Job should take about 2 weeks, after that the brakes will be upgraded to ABS. Greetz Rudy
Old Nov 15, 2019 | 08:11 AM
Jose's Avatar
my '84 sttill has the original Girling shocks and factory springs. No reason to change them.
petemohr
Oct 11, 2019 03:31 PM
Greg in Tampa
Aug 16, 2019 06:05 AM
Jimmy James 905
May 15, 2015 09:50 PM
EJ Garity
Mar 29, 2014 02:40 AM
RonaldP
Jun 13, 2013 06:14 PM
