Remote Starter
Old May 17, 2023 | 01:08 PM
sawmkw's Avatar
Default Remote Starter
I'd like to put a remote lock/starter on my 85 XJ6. Has anyone ever installed, or had one installed. Any reason I should not do this?
Old May 18, 2023 | 09:09 AM
Jose's Avatar
never heard from anyone doing it, maybe a remote starter, but not a remote lock.
Check with J.C. WHITNEY for a universal remote starter kit.
Old May 20, 2023 | 09:16 PM
xjtom's Avatar
cheap on Ebay and easy enough to fit, most will do door lock/unlock - alarm & remote engine start...fit any car
Old Jun 29, 2023 | 12:38 PM
sawmkw's Avatar
I checked with several shops in the area and only one admitted to ever trying a remote starter. He said it took 2 days and never did work quite right and would never do it again. The other shops said they would not even try it. A remote door lock wouldn't be an issue.
Old Jun 29, 2023 | 02:15 PM
geneo's Avatar
I had a remote lock installed in my 77 coupe. When to a local stereo installer. It was a number of years ago, but it worked great. I will be re-hooking it up as I finish the restoration.
geneo
Old Jul 4, 2023 | 09:37 AM
benji808's Avatar
I installed an old bulldog remote starter in an ‘86 Lincoln back when I had next to no mechanical or electrical experience. It’s pretty simple- the unit is basically a relay that connects the 12v constant wire that goes to ignition with the wire to the starter relay. You can also tie that in to a door lock wire, trunk release, lights (if you want them to blink when you press it) etc.
Don’t see any reason it wouldn’t work for a fuel injected XJ6 (carbs might be tricky unless you had an electric fuel pump, since you wouldn’t have a way to prime it).
dcmackintosh
Mar 31, 2018 11:43 PM
DrRedAxel
Feb 5, 2015 11:35 PM
bone64
Aug 25, 2011 04:53 PM
MDJag
Jan 2, 2010 10:37 AM
hinesks
Dec 5, 2008 10:34 PM
