Remove Catalytic Converter 1982 XJ6 Cause Issues?
Good info, Doug, tks. I'm trying to get my new downpipe installed and was told that without replacing the O2 sensor, the check engine light will stay on...any thoughts here?
Your ‘82 doesn’t have a check engine light.
It probably WILL have a catalyst warning light. This is triggered by miles driven via the “Intervalometer”….which has no idea if the converter is in place or nor
Update...was able to read thru the posts above, and now understand I will need to add the sensor to the new pipe. Is it possible to reuse the sensor in the car, or should I go with a new part?
Thanks for the feedback!
hofmann308
Nov 23, 2012 09:32 AM
