replacing the distributor on my 86 xj6 series III
Old Oct 20, 2024 | 03:13 PM
jerome currier's Avatar
I've installed the PerTronics distributor D171618 and coil #45011. I am getting a spark at the coil but not to any of the spark plugs. I have removed the amplifier, should I reinstall it?
Old Oct 20, 2024 | 04:08 PM
David84XJ6's Avatar
If you are getting spark output from coil, but not to plug wires, it is distributor timing or spark plug leads to cap not in correct location. If you pull center lead out of cap and get a spark from it then recheck timing and lead location on cap. The amplifier can not not help, just make sure amplifier mounting holes have been closed with 3/4" long bolt or you will get a vacuum leak.
Rgds
David
Old Oct 20, 2024 | 05:02 PM
David84XJ6's Avatar
Installation Steps
  1. Remove old distributor: Disconnect electrical connectors and remove the old distributor.
  2. Install new distributor: Gently push the D171618 distributor into place, ensuring it seats properly. If it doesn’t seat, gently bump the starter or hand-turn the crank to help it fall into place.
  3. Align rotor: Crank the engine around to No. 1 compression stroke and ensure the rotor is at the correct position (No. 1) on the cap.
Number 3 is most important to get #1 on compression stoke. The trimming mark on vibration dampener should be at 10* for this check.
Rgds
David
Old Oct 20, 2024 | 05:49 PM
Thanks Dave, I'll give this another look in the morning.
Old Oct 20, 2024 | 09:24 PM
David84XJ6's Avatar
If still no joy, contact Pertronix Customer Support, to see if they have quick checks to resolve your issue. They are a California company for business hours.
Rgds
David
Old Oct 22, 2024 | 03:43 PM
Thanks again David, I finally got it going yesterday. Stupid me had the distributor set 180 out. Also appreciate letting me know about the vaccum created by removing the amplifier, I would have certainly missed that.
Old Oct 22, 2024 | 08:07 PM
David84XJ6's Avatar
Thanks again David, I finally got it going yesterday. Stupid me had the distributor set 180 out. Also appreciate letting me know about the vacuum created by removing the amplifier, I would have certainly missed that.
Don't take it too hard, I have had 3 Jags and have set my Distributor 180 out, one time also. Glad to hear your up and running.
Rgds
David
DaveinG
17
Aug 2, 2023 03:13 AM
retroren
Aug 12, 2021 09:47 AM
Fingers13
Feb 6, 2021 12:10 PM
Exodus82
Jul 20, 2019 10:01 PM
sneal46
Nov 8, 2010 10:58 AM
