Replacing steering rack on Series 1
Old Oct 29, 2018 | 10:19 AM
INDYJAG-84's Avatar
Default Replacing steering rack on Series 1
Looking to purchase replacement steering rack for my Series 1. I see refurbished units for $325. Any recommendations for replacements/vendors?
My current rack was supposedly rebuilt before I purchased the car in Feb. 2017, but it started leaking shortly after I got it. Any procedure to flush out the system before installing new one?
What type fluid are you using?
Regards,
Old Dec 14, 2018 | 11:57 AM
shtekler's Avatar
I have a good answer for you read my answer on
xj40 Power Steering Rack Rebuild
or try to find it on my answer with my name shtekler
Old Dec 14, 2018 | 06:01 PM
INDYJAG-84's Avatar
Shtekler,
Thanks for the response. According to Haynes manual they originally used ATF in the power steering for my model year 1973. I was planning on using the same, absent someone giving any reason not to.
I had my rack rebuilt locally for about the same price as getting a re-built unit from California.
The post you referred me to makes sense to me about high pressure from the pump causing seal failure.
My car was lumped with a '70's 350 sbc utilizing the Chevy power steering pump.
I wasn't planning on measuring the pump output pressure but I 'know of any other way of being sure it's compatible with my Jag rack.
So can anyone tell me if the Chevy pump pressure setting may be the problem or any other opinions out there?
rusty37
Apr 5, 2020 07:40 PM
mrobinson
Jul 21, 2016 05:32 AM
SaturnV
Nov 6, 2013 01:12 PM
retroguybilly
Sep 2, 2009 11:24 AM
bert_vdp
Jan 13, 2009 04:06 PM
