Rough idle at start
Old Sep 22, 2016 | 06:14 PM
albjerryg's Avatar
Default Rough idle at start
I have a 1981 XJ6 with fuel injection. It starts fine but idles rough and at about 400 to 500 rpm for 4 minutes then it goes to normal idle about 800 rpm and runs good. I can't believe it is the cold start injector it is always 90 degrees here. Any suggestions. Thanks,,,,,,Jerry
Old Sep 22, 2016 | 11:19 PM
Doug's Avatar
The 'could be' list might get long. Here are some starters
Might be.....
XJ 6 Series III 4.2 - Cold Start EFI Overfuelling
Might be that your AAV isn't working. This is what increases idle speed on a cold engine
Descripton and Function of Aux Air Valve, Series III XJ6
Might be that your coolant temp sensor is skewed. it plays a major role in fueling until coolant hits about 160ºF
Testing the Coolant Temp Sensor
Old Sep 23, 2016 | 09:07 AM
albjerryg's Avatar
Default Rough Idle at start
Of the 3 thing you listed I have already replaced 2. The AFM and the coolant sensor. So the only one left is the AAV. thanks,,,,Jerry
Old Sep 23, 2016 | 09:43 AM
Doug's Avatar
The first item on the list is a wiring modification , not AFM replacement
Old Sep 23, 2016 | 09:59 AM
albjerryg's Avatar
At one point the car ran fine so I am thinking it is not a mod to the wiring plug.(I hope).....Jerry
Old Sep 23, 2016 | 11:00 AM
JagCad's Avatar
Perhaps, just a burp of the throttle on start up to clear any extra fuel in the cylinders or manifold. A dripping injector or two might cause that.
My lump does that once in a while, a slight roll, indicative of running just a bit rich.
Carl
Old Sep 23, 2016 | 12:06 PM
albjerryg's Avatar
I checked the AAV as described and it is closed when cold and closed when it get up to temperature, I also checked the plug and it does have 12 volts when running. I guess it is bad. (enclosed are pictures with engine cold). I guess I should remove it and try to clean it. Is the 2 allen screws the only thing holding it to the water rail? Thanks for the help.....Jerry
Attached Thumbnails Rough idle at start-img_0791.jpg   Rough idle at start-img_0795.jpg   Rough idle at start-img_0796.jpg
Old Sep 23, 2016 | 12:27 PM
Doug's Avatar
Yes
Cheer
Old Sep 23, 2016 | 12:51 PM
albjerryg's Avatar
I tried bumping the throttle but it speeds up and then goes back down and does the same thing until 3 or 4 minutes have passed. Thanks Doug....jerry
Ktc4319
Sep 21, 2016 06:51 PM
jerry_hoback
XJ40 ( XJ81 )
Sep 19, 2016 08:55 PM
fox5mx101
Sep 19, 2016 01:06 AM
theweeb
Sep 17, 2016 04:35 AM
albjerryg
Sep 16, 2016 08:09 PM
