screeeech!!!
Old Nov 6, 2011 | 07:45 AM
doghead08's Avatar
Default screeeech!!!
my 86 xj6 makes an appalling sound in the morning when i turn the steering wheel
i had the belts replaced recently when i did the water pump
i checked and all fluids are at proper levels
what am i missing????
Old Nov 6, 2011 | 08:40 AM
Doug's Avatar
Recheck the belt tension. It's not unusual for new belts to stretch and slacken shortly after installation
Old Nov 7, 2011 | 01:05 PM
doghead08's Avatar
Default belts
i checked the belts and they seem ok. what is the litmus test to determine what too much slack is?
the sound seems to be coming from the bottom of the rod going from my engine compartment to my steering wheel
Old Nov 8, 2011 | 03:24 PM
sneal46's Avatar
I concur with Doug. Put new belts on recently and they squealed shortly thereafter. Just tighten up the tensioners a few turns and see if the noise stops.
Old Nov 8, 2011 | 04:10 PM
Per's Avatar
Per
Simple check is to try anti squeal spray on the belt.
Old Nov 9, 2011 | 08:11 AM
doghead08's Avatar
Default belt spray
i tried the spray and it doesnt do anything
when im backing out of a spot and..i sometimes feel tension while cutting the wheel
as i said earlier when i open the hood it sounds like the noise isnt by the belts but maybe the power steering pump
faulty pump maybe?
Old Nov 9, 2011 | 08:29 AM
Doug's Avatar
Find the longest span of the belt and press down firmly with your fingers. If the belt deflects more than about 1/4" it's too loose.
Old Nov 9, 2011 | 08:32 AM
Doug's Avatar
faulty pump maybe?
Could be the pump but, really, I wouldn't contemplate any others repairs or problems *until* the belt has been re-tightened. What you're describing has all the earmarks of a loose belt. Just tighten it and see what happens.
Old Nov 9, 2011 | 10:55 AM
doghead08's Avatar
will do as soon as i get done w/ work...thanks a bunch fellas
