series 3 has started idling high and leaking fuel
Old Apr 29, 2015 | 08:03 AM
jjd's Avatar
jjd
Default series 3 has started idling high and leaking fuel
As title says, my series 3 on carbs, is suddenly idling at between 1500 to 2500 rpm and the overflow pipe on one of the carbs is pumping out petrol onto the ground. Whats the diagnosis folks?
Old Apr 29, 2015 | 08:07 AM
Jose's Avatar
the high idle can be a vacuum leak, a stuck linkage, or the throttle return spring is missing or "sprung", not pulling the linkage back.
Old Apr 29, 2015 | 08:09 AM
Jagfixer's Avatar
Stuck needle seat.
Old Apr 29, 2015 | 10:18 AM
jjd's Avatar
jjd
Yep needle seat it was. Wasn't going all the way back into position due to gunk! Took it apart cleaned it up and its fine now. Also did other carb as well. Cheers chaps.
Old Apr 29, 2015 | 04:00 PM
Fraser Mitchell's Avatar
This must be one of the rare 3.4 litre cars. A good engine.
Old May 3, 2015 | 02:13 PM
jjd's Avatar
jjd
Yep not many 3.4 series 3's round these parts. 1985 with carbs and aed, also cloth seats and less veneer and chrome than 4.2 siblings. It has been upgraded to sovereign spec over years. Solid all rounder she is.
toronadomike
Jan 22, 2026 10:13 PM
allenman85
May 10, 2021 03:11 PM
Russ Graber
Feb 23, 2019 11:59 AM
alpecsa
Sep 7, 2015 11:55 AM
tberg
Sep 7, 2015 07:32 AM
