Series II Vacuum HELP!
Old Jun 2, 2013 | 12:19 PM
DreWRoolZ's Avatar
Question Series II Vacuum HELP!
A vacuum line fell off of my car & I do not see where the other end of it hooks up at to reconnect it. The one end connects at the firewall or inner fender on the passenger (Right) side of the engine bay. The line is only about a foot long but I cannot see anywhere for it to hook up to (& I know it was hooked up because I used it to suck Seafoam into the car once before & it had suction so I know it's not a leftover from the conversion).. Any help would be greatly appreciated. Also the location of the vacuum canister if anybody knows that too. I am having transmission trouble and was told it may be vacuum related by the transmission shop down the road so I am trying to get everything inspected and hooked up properly. Thanks!
Old Jun 2, 2013 | 03:19 PM
Fraser Mitchell's Avatar
As I recall, the vacuum reservoir was on the RH side right at the back of the wheel arch inside the engine bay underneath the wing. It's about 4" across. On the other side is the windscreen wiper motor. It may be the other way around on US cars, as I'm describing my old Series 3 I had up to 2002.
As your 'lost' vac line is so short, might it not need connecting to the vacuum-controlled heater water valve on the bulkhead ?
Old Jun 3, 2013 | 09:46 PM
Sean W's Avatar
Default Series II Vacuum HELP!
Not sure about the series II but on the series III the vacuum reservoir is opposite side of the windshield wiper motor as the previous poster suggested, in the engine bay, under the fender - look under the fender by the brake booster. Regarding the vacuum line, one comes out of the firewall to the heater valve control on the center of the firewall. The other is to a check valve, probably hidden under some wires just above the connections (next to and above the battery. I hope this helps.
Old Jun 5, 2013 | 03:29 PM
DreWRoolZ's Avatar
I'm still trying to figure it out but it seems to be running beautifully without it lol but if it's supposed to be there then I would like it to be hooked up right *shrugs* speaking of wiper motor I need to see if I can get those working again too... they worked one time when I first got the car I accidentally turned them on, got them to turn off and now they don't work at all lol always one thing after another with this thing but it's definitely worth the pain
Old Jun 5, 2013 | 07:33 PM
stellar-warior's Avatar
the wiper issue is probably just a loose connection, at least that's where I'd start looking. its always nice when a problem is as simple as replacing a spade connector, instead of the whole unit, whatever it may be haha.
Old Jun 10, 2013 | 12:40 PM
Frank van den Brink's Avatar
Default Vacuum
Had the same problem last Friday.... At the underside of the inlet manifold, I found the connection for the vacuum tube to the distributor.
I have a Daimler sovereign 4.2 (aka Jaguar XJ type III) 6 cylinder...
I hope this helps
Old Jun 10, 2013 | 03:10 PM
Bob Kontak's Avatar
I have a 1977 XJ12L with 20k miles I am working on. Only saying this as it is bone stock.
The only vacuum line that I see on the passenger inner fender is in the photo. It connects to a metal line on the engine side and snakes under the v-shaped black metal tubes joining in the center of the cowl. It feeds the power brake booster. It is hard to see the metal tube the hose connects to as it is hidden under the black tubes.
From the inner fender side of the hose a metal vacuum tube runs towards the front of the car (behind some plating and plastic bits) and then down towards the bottom of the radiator where it passes through the inner fender into the wheel well where you will find the vacuum cannister.
Edit - I don't know much about these cars but the cannister (a cannister at least) is in the front of the tire -far forward under the fender.
tomkilner
Oct 9, 2015 07:10 AM
k-man
Oct 5, 2015 08:09 AM
Johncy2000
Oct 2, 2015 01:05 AM
