Speedometer
Old Jun 22, 2016 | 05:46 PM
albjerryg's Avatar
Default Speedometer
I have a 1981 XJ6 and it has mechanical speedometer and placed a drill on the input and no reading on the gauge. I traced the cable to a white plastic box on the firewall the cable goes in this box and come out and goes to the front of the engine. I assume it goes around and into the instrument panel . I have not got that far yet. What I want to know is what is this plastic box it has a plug also but was not plugged in anything. I am assuming that the spedo cable is bad somewhere . Thanks for any input. Jerry P.S. it was working a week ago.
Old Jun 22, 2016 | 10:43 PM
Doug's Avatar
The box is the "Intervalometer"...or some silly name like that. Every 30,000 miles an internal switch closes to turn on the oxygen sensor warning light. There's a reset button on the box to restart the count.
Most people get a one piece replacement cable and ditch the box
Old Jun 23, 2016 | 07:26 AM
albjerryg's Avatar
OK that make it easy I will ditch the box, where can you get a male to male connector to connect the 2 cable drives, or t you just replace the hole cable. Thanks Jerry
Old Jun 23, 2016 | 10:03 AM
Doug's Avatar
Not sure about a connector. The usual thing is to just buy a new, single cable. I would contact 'one of the usual' Jag vendors (SNG Barrat, Jagbits, Coventry West, Welsh, etc). they should be able to fix up up
Old Jun 23, 2016 | 12:16 PM
albjerryg's Avatar
Default Speedometer
Ok thanks, look like it is the box that is bad, when I hook the drill up to the cable going into the car the speedometer works. Thanks Jerry
LnrB
Feb 27, 2017 02:48 PM
frostee
Apr 21, 2016 08:50 PM
TrunkMonkey
Apr 18, 2016 08:31 AM
XJsc-guy
Apr 12, 2016 02:09 PM
XJsc-guy
Apr 5, 2016 10:11 AM
