Speedometer issues
Old Apr 14, 2016 | 09:56 AM
TrunkMonkey's Avatar
Default Speedometer issues
I recently acquired an '87 XJ6 and since I got it the speedometer needle will get stuck at approximately 77 MPH, it wont come back alive until I slow down to around 70 MPH. Just recently the needle started sticking at 0 and popping up to 20.
I changed out the transducer on the transmission this last weekend, it seemed to fix the low end for a couple days but it is back to popping up to 20 now. It never seemed to fix the sticking at 77 issue.
I was wondering if any of you may have an idea as to what may be causing the problem. I am thinking it may be something internal to the speedometer itself.
Stephen
Old Apr 14, 2016 | 10:19 AM
Welcome to the forum Stephen,
I think you probably have an XJ40 like the one here and not an XJ6 Series III:
Often confusing as both have an XJ6 badge on the back!
Please confirm and I'll move your question to the correct model forum.
Old Apr 14, 2016 | 10:58 AM
It is in fact a Series III XJ6 and not an XJ40
Old Apr 14, 2016 | 12:42 PM
I'll leave it here then!
Old Apr 14, 2016 | 11:53 PM
Doug's Avatar
Stephen
Which is certainly plausible. For most of us that means seeing an instrument specialist or installing a used speedometer
But ....did you install a used transducer? If so, it might have problems of its own, as problems are quite common.
Old Apr 15, 2016 | 08:39 AM
The transducer I installed was a new one. I have a used speedometer on the way from eBay hopefully it fixes it, if not I will try to find a speedometer shop that is willing to take a look at it.
Old Apr 18, 2016 | 08:06 AM
I received the used speedometer over the weekend and tested it out. There seems to be no issues of the needle sticking at this time. I just have to find a speedometer shop that would be willing to adjust to the correct mileage now.
Old Apr 18, 2016 | 08:10 AM
JagCad's Avatar
Why????
Turning back the "clock" is a sensitive thing in a lot of places!!!
Carl
Old Apr 18, 2016 | 08:31 AM
I am kind of OCD when it comes to numbers and I know it is going to bug me that the mileage shown is 50,000+ more than what is actually on the car.
I do doubt I will be able to get it accomplished though
