Speedometer Error
Old Sep 8, 2014 | 07:53 AM
Dale Konkol's Avatar
Default Speedometer Error
My speedo seems to be showing slower speeds than actual. The trip computer seems to be right on as far as indicating actual speed. I hold the reset button on the t/c while reading "average speed" while traveling at set speed thru one of those police speed trap/indicators and the t/c is right on. Speedo reads 30 mph, t/c shows 32. Speedo 50, t/c 53.6. Speedo 70, t/c 76mph.
I was thinking it might have something to do with the new 16" lattice and tires I just put on. But they are the same diameter within .3" (taller) of the original oem size tires. P225/60/16 vs. P215/70/15.
I wonder why the trip computer is right on but not the speedo. And I wonder if it hasn't always been this way but I just hadn't noticed. I would think I would have noticed since owning the car since '93. Never a speeding ticket in that car and I do tend to push the 5-10 mph window the cops will allow you.
Is there a fix to this, or should I just live with it?
Thanks.
Dale
Old Sep 8, 2014 | 08:11 AM
Doug's Avatar
The speedo and the TC share the same speed sensor and most of the same wiring. A tire size change would affect both equally, it seems.
Normally a speedometer reads too high...in which case your slightly taller tires would bring the reading downward....towards a more accurate number.
But that's not happening in your case.
I'd say the problem is actually inside the speedo itself
Old Sep 8, 2014 | 10:34 AM
Mikey's Avatar
I'd find a better data source than the speed trap indicators. Almost all GPS units will display vehicle speed. By law, actual vehicles speed must be the same or lower than gauge indication, but never higher.
Incorrect tire size is the most common source of error.
ricwel
Jun 23, 2023 05:14 PM
jimforrest (uk)
Feb 28, 2019 06:42 PM
Poet
Oct 2, 2015 09:00 AM
Collector1
Sep 28, 2015 03:52 AM
