Speedometer intermittent
Old Sep 11, 2011 | 12:07 AM
86JAGVP's Avatar
Default Speedometer intermittent
Every so often I look down at the speedometer while driving and the needle is on zero. After fifteen to thirty seconds it shoots up and settles back in to where it should be. Does the series III use a cable driven system, or does it use some type of sending unit?
Old Sep 11, 2011 | 06:35 AM
Doug's Avatar
Until '83 or so a cable system was used. After that Jaguar went to an electric speedo using a signal generator....usually called a "transducer". It's on the right side of the trans, towards the rear. It's almost always the culprit when the speedo starts doing strange things.
Old Sep 13, 2011 | 11:00 PM
86JAGVP's Avatar
Wow! Those transducers are spendy little critters.
Ferdie
Nov 26, 2018 05:42 AM
Marka
22
Sep 11, 2016 12:09 AM
Moghut
Oct 1, 2015 01:55 AM
Listers
Sep 30, 2015 07:45 AM
