starter cranked 2-3 turns then everything died
Old Dec 29, 2022 | 08:14 PM
awg294's Avatar
Default starter cranked 2-3 turns then everything died
Hello all, Happy Christmas,
So, my xj6 has been sat in the garage on a trickle charger, I usually remember to start her up every couple of weeks if she's not been use, and he was running a couple of weeks ago, so I went to start her today, the starter turned the engine 2-3 times then everything went dead - no lights on the dashboard, nothing, when I turn the ignition key everything is completely dudd,
any advice on where to start? I guess there's no fuse for the starter, presumably one of the relay switches on the bulkhead? or could it be that something's just gone kaputt in the key column switch and no current is flowing when I turn the key?
thanks in advance for any thoughts, best wishes, Al
Old Dec 29, 2022 | 08:26 PM
Doug's Avatar
https://www.jag-lovers.org/xjlovers/xjfaq/nocrank.htm
Old Jan 2, 2023 | 11:10 AM
rfarmery's Avatar
I would be inclined to check earths first. Usually a good place to start especially if there is absolutely nothing happening when you turn the key. I have been in similar situations where you can crank initially and then nothing.
Old Jan 2, 2023 | 08:41 PM
Andy T.'s Avatar
It could be the battery itself. Sometimes they suddenly die - it happened to me recently on a different classic car I have
Old Jan 2, 2023 | 11:18 PM
JagCad's Avatar
Clean the cables and posts at the battery.
slmskrs
Jul 15, 2019 10:48 AM
b787
Jun 18, 2015 05:08 PM
Earsti
Nov 21, 2011 07:26 PM
chokeu2
Feb 17, 2011 09:37 AM
tsingtao35
Jun 28, 2010 10:43 PM
