Starting issues.
Old Nov 12, 2023 | 09:42 AM
gooseman1107's Avatar
Default Starting issues.
So I have a 1997 Jaguar xj6 and I tried to change the starter. It has times where it would try to start but the gear inside the starter wouldn't shoot out do you had to wait till it stopped spinning then try again and it would start.
so my girlfriend is in grad school an hour and a half away do I wanted to change the starter so she wouldn't have to wake up to a car that wont start.
So I got the bottom bolt off real easy on the starter but that picky top bolt put up a fight and I wasn't able with the tools I have to get to it, so I went and bought the one I needed. But now I tried to move the car and it won't start.
I never took any wires off or unplugged anything aside from disconnecting the battery. So besides the starter motor i can figure out why it wont start. Only thing as i pulled the positive off the battery was oh crap I should have unlocked the doors eith the key first (that pesky jaguar security system) but I didn't. Also I tool 2 bolts off one was for the clamp that holds the wiring loom for thr fuel injection and one bolt that holds a metal hanger for 3 plugs as your looking at the back drivers side (USA) of the motor it was to just make moor room for tools and such.
Since I have check all the fuses and locked and unlocked the car many times but still nothing, I have placed a jumper on the battery incase that was to low as well.
I put the key in and with the door open it will chime so I know the security system isnt stopping from that point. But as soon as you turn to the on and try to start nothing happens but I notice the lights in the car will go out then turn back on, I'm not sure if that's anything.
I'm thinking to just continue the starter motor and hope that it is the problem but i also want to know i didnt do something before hand too.
Any help would be greatly appreciated!
Old Nov 12, 2023 | 11:30 AM
Fraser Mitchell's Avatar
You've posted in the wrong forum. If you look at the forum title you'll see this is for XJ saloons Series I to III up to 1992. However the 6-cylinder cars ceased in 1986. although the V12s carried on until 1992 albeit very few, like about 50-60 a week. You car is probably the X300 with the AJ16 straight 6 all-alloy engine. Curvy like the old XJs but with no common parts.
Old Nov 12, 2023 | 11:48 AM
Ok thank you. I didn't notice that!
Tomthecarguy
Jan 28, 2018 07:31 PM
razorboy
Nov 11, 2015 10:24 AM
NTL1991
XJ XJ12 ( X305 )
Apr 6, 2015 09:40 PM
Sparty
Sep 20, 2011 09:34 AM
chokeu2
Feb 17, 2011 09:37 AM
