Steering column wiring
Old Jul 7, 2007 | 11:16 PM
93xj6's Avatar
Default RE: Steering column wiring
What year is your car man?
I would recomend just going to the dealer with that one, I never even heard of anybody going into the steering wheel column before to fix wiring, so I'm clueless
Old Jul 8, 2007 | 07:35 AM
Jose's Avatar
if it came from inside the steering column, it's the horn/claxon wire, and yes, it is usually blue. but you need to specify your car year and model so that those who know your car can help.
Old Jul 8, 2007 | 05:37 PM
Jose's Avatar
did you pull the wire out of the column? or is it just there? if it is the horn/claxon wire (just 1 wire), then you can follow the black steering column down to the gas pedal where you will see an oval cutaway in the column, that's where the horn switch connection is.A picture would help.
what is confusing me is that the turn signal switch does not have any wires into the steering column, it only has a rubber plug which mates with another rubber plug on the main harness.
The turn signal switch contains the Set switch for the Cruise Control, (black wire coming from the stalk push-button), and the Flash to Pass switch for the headlamps, as well as the High Beams switch.
It can be rebuilt with lots of patience and know-how, but when removing it, a lot of disassembly is required including removing the Hazard Switch which is part and parcel of the Turn Signal Switch.
The Blue wire you might be referring to may be the separate blue wire for the High Beams, which has a separate connector, but spliced into the main harness behind the dash.
H20boy
Dec 24, 2024 03:23 PM
2001 White XJ8
Feb 25, 2021 05:02 PM
kevinl
Oct 31, 2019 06:15 PM
1964Daimler
Sep 9, 2015 11:28 AM
laserguy
Sep 3, 2015 02:02 PM
