sunroof problem
Old Jul 8, 2012 | 06:17 PM
wiggy's Avatar
Default sunroof problem
hi,ive got a series 2 double six coupe 1978 with an electric sunroof that is stuck open by about 2 inches.the electric motor is in the rear of the roof not in the boot. can anyone tell me how to close it manually and where the tool to do it might be .
Old Jul 8, 2012 | 07:50 PM
Jose's Avatar
all I know is that Series 3 came with a little crank tool that lets you manually crank/turn the motor from the boot if the motor should fail. Some came with the tool in the glove box, some came with the tool in the boot, at least in the USA they did.
not very familiar with the '78 Coupe. But if no other experienced tips come forth, then I would ((as a last resort)), disconnect the geared cables from the sunroof motor assuming you don't have to remove the headliner to get access to the sunroof motor. Once the cables are removed from the motor's toothed gear, the sunroof should be freer to move.
Old Jul 9, 2012 | 07:14 PM
wiggy's Avatar
thanks jose,i found the crank tool in the car today (GLOVE BOX)and managed to close sunroof.i have been trying to find a replacement motor but have had no luck so far.got a few more places to try tomorrow.
thanks again.
Old Jul 9, 2012 | 08:27 PM
Jose's Avatar
you welcome wiggy, glad to hear the news, it almost sounds as if the '78 Coupe motor is the same as in the Series 3 all the way to 1992, so you could try a Series 3 sunroof motor, or have yours rebuilt.
Old Jul 11, 2012 | 05:45 PM
wiggy's Avatar
you might be right jose about series 3 sunroof motor,because my car was one of the last coupes built,(number 369 out of 372 double six coupes).so i'll try series 3, or where could i get it re built,do you know anywhere Jose?.
Old Jul 12, 2012 | 05:05 AM
Jose's Avatar
are you in the USA? if yes, I know a rebuilder in Maryland, but I think you can find a used motor for less than it costs to rebuild it. Have you checked eBaY for a used motor??
also check with David at Everyday XJ he has Series 2 and 3 parts.
Old Jul 22, 2012 | 03:43 PM
KevinBrick's Avatar
Default Series II sunroof motor
There is a series II sunroof motor on ebay auction # 310036490473 with picture and part # which might be helpful for around $75.00 . I would test the old one first to make sure it's not just the switch which was my problem.. A new switch is arond $15.00. You can test the switch by repacing it with one of the identical switches that you know works.. A shot of electrical parts cleaner on the connections seemed to help as well..
Old Jun 5, 2013 | 10:10 PM
pussycat's Avatar
You do not need a special tool just in case you lost yours.
A shifter will do the job.
On my Sun roof electrical motor there are two rollers which you can rotate manually forward and backwards to control the geared cable.
Now can anybody help me in outlining the steps in removing the whole sun roof structure from the underside the roof without using a grinder?
I really do not want the use my angle grinder and cut around the sunroof structure.
Where the S/R sits up front it is penned and glued whilst at the rear it is loose.
TexasCat
Sep 8, 2015 04:36 AM
mcdutch
Sep 4, 2015 03:38 AM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
King Charles
Sep 3, 2015 12:40 AM
