Sway bar link question/transmission question
Old Sep 19, 2015 | 05:42 AM
ahunt4's Avatar
Default Sway bar link question/transmission question
First question is can bushings be bought at a auto parts store to replace the ones on a sway bar link. Does anyone know the thread size of the nuts that connect the sway bar link?
The transmission question is I have adjusted the bands but I can't accelerate fast from 1st to 2nd without the tranny slipping for a second then finally catching. Any ideas? Xj6 series 3
Old Sep 19, 2015 | 05:46 AM
o1xjr's Avatar
It would be best to ask your two questions in seperate threads as they are irrelivant to each other and answers could get confusing.
I have answers to neither but someone will be along soon with some ideas.
Old Sep 19, 2015 | 06:46 AM
The nuts on the hex links are 14mm or 9/16A/F, from memory, or is it the hex is 14mm etc and the nuts are 13mm (1/2"), bugga, I forget, its been a long, long time.
The bushings are generic down here, nothing special, such as GM, Ford, whatever I find on the day in the parts boxes. I never use Poly here, as the hex studs have a bad habit of snapping with that compound in there.
The trans, try an extra litre of fluid, maybe the gasket on the filter spacer block is split/missing, and the pump is sucking air coz its easier. No harm will come of the trans with this slight "overfill". When you get to about 4litres over, then panic a little.
Failing that making ANY difference, the trans is worn out, it does happen.
bamforp
Aug 14, 2024 05:36 PM
Jandreu
Jun 30, 2022 03:10 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
Steve10
Sep 9, 2015 07:54 PM
kstevusa
Sep 7, 2015 01:12 PM
