Tank Change Over Return Valve
Old Jun 12, 2015 | 10:06 AM
Originally Posted by JagCad
Synopsis:
1. Right, yes, left, no! as to voltage to the change over valve.
2. Elinor, better than you think. *** your tanks are T'eed together, it merely takes some interpolation. If the car is on level ground the reading on the guage is the same for either tank. If on a slant, not so much. Then, extrapolation required!!!
3. Fall back, if in doubt, off to the gas station!!!
Carl
They're Tee'd together, Carl, but I think there's a back flow valve in there somewhere, probably a couple of them, because the tanks do Not drain equally. I usually put around 8 gallons in the left tank and 2 gallons in the right tank. Not only that, no matter how long it sits, the tanks don't equalize.
The engine draws off the left tank first until it's well below 1/4 and I'm getting Really Nervous, but then the gauge doesn't drop anymore and she just keeps going and going and going, obviously drawing from the right tank.
I calculated I have a range of over 400 miles anyway, but mostly because it's not right, I would like the gauge to work.
Old Jun 12, 2015 | 12:53 PM
JagCad's Avatar
At times plumbing mysteries equal electrical issues.
If the Tee is a simple connecting the low points of each tank, one would think they would equalize via the Tee.
And, as a carb car, no electric pump and return lines. Simple, or should be.
But, a back flow preventer in each line to the Tee? Sounds really clever.
But, how the logic is constructed to feed from the right tank til it is empty than the left is unkown. More clever work?
So, in effect, your right tank is the service tank and the left functions as a reserve.
Not bad at all.
And, the way to read each tank went with the individual fuel pumps, as when it was a carb'd DOHC!
I suppose the float and rheostat is still in the left tank. perhaps the wires are cut and taped off. or merely an open of unknown etiology.
Carl
dsnyder586
Dec 29, 2024 07:39 PM
alpecsa
Sep 7, 2015 11:55 AM
David Thompson
Sep 3, 2015 07:48 PM
XFR_Gold
Sep 2, 2015 12:24 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
