Thumping sound when accelerating.
Old Dec 11, 2017 | 11:49 AM
Isaac Pagan's Avatar
Default Thumping sound when accelerating.
Hello!
Took the car for a short drive yesterday, and started noticing a thumping sound coming from the rear axel. It only happens when accelerating. And if I accelerate slowly, it doesn't make any noise. Transmission? Thanks in advance, gang.
Old Dec 11, 2017 | 04:25 PM
Jose's Avatar
could be many things, a muffler or pipe Hanger, a bad U Joint, a bad Transmission Mount,
if the transmission is shifting ok, then it is not the transmission, most likely, it is the transmission Mounts, they are rubber and deteriorate with age, a 1983 is a candidate for replacement transmission mounts. Get new ones on eBay. They are very similar to engine mounts.
Old Dec 12, 2017 | 11:58 AM
sov211's Avatar
Originally Posted by Isaac Pagan
Hello!
It is the transmission mount. This is exactly the symptom of a badly deteriorated mount - when you have it replaced make sure that the mechanic installs it correctly (meaning that he/she has observed how the original was configured).
Molineux
Apr 18, 2025 07:38 AM
Vancouverguy
Nov 11, 2021 09:04 PM
totalimmortal363
May 5, 2014 05:25 PM
canadajag
Aug 26, 2010 06:14 AM
MTZGR777
Apr 12, 2010 04:55 AM
