Timing xj6 s2
Old Jan 20, 2025 | 06:24 AM
mickvic's Avatar
Default Timing xj6 s2
Okay humour me, jag s2 4.2 1975 ....which cylinder do we do ignition timing off...I put the strobe on number six (front) and got nothing. Timing mark is in white paint. 8 degrees. So I should put the strobe on number 1 (back)?
Old Jan 20, 2025 | 06:39 AM
Hell-Cat's Avatar
No 1 cylinder is nearest the firewall (e.g. at the back of the engine), you need to time off that cylinder - yes, it's a Jaguar thing.
Old Jan 20, 2025 | 07:13 PM
mickvic's Avatar
Cheers thanks!!!
Old Jan 20, 2025 | 11:29 PM
Scd's Avatar
Scd
Hi, I would check your strobe light and/or the plug lead. It won’t make any difference if you time it on no 1 or no 6 assuming you have a running engine . Timing on the compression stroke of the rear (no 1 piston) is only required when the head has been off and you are setting the camshafts and distributor. Good luck.
59mk1*
Jul 6, 2021 09:54 AM
dirtyharry
Apr 21, 2021 09:13 PM
iramphal
May 4, 2018 10:14 AM
albjerryg
Aug 22, 2016 08:17 AM
huanpham_65
Aug 17, 2014 04:34 PM
