Tires
Old Nov 1, 2010 | 06:16 PM
wradford's Avatar
Default Tires
can someone advise me on tires. My local tire store doesn't seem to be able to locate the correct v rated tires for my 88 xj12 . Any particular places to look? It may be worth my while to travel to Seattle.
Old Nov 5, 2010 | 11:02 PM
DrDodge's Avatar
You're right that V-rated tires are hard to come by in a 15" wheel diameter. "V" is a tire rated to 149mph. Do you really need this? Much discussion has been done in the past on this. I run Goodyear Assurance Comfortread on my car which are rated "T" or 118 MPH. Does this mean it's not safe to run to, say 125 MPH for a few minutes? Not really. These ratings are for 'sustained' MPH.
Choose a tire that suits your driving style and comfort requirements. Speed ratings are only there if you are looking to exceed them.
Hope this helps!
Jeff
PS: Comfortreads are NOT a good choice for the XJ. They are too soft and feel very unstable in a heavy car like this.
Old Nov 6, 2010 | 01:34 AM
Doug's Avatar
I agree wirh Dr. D on the speed rating thing. However, you might find a V-rating if you look for a 225/60x15 or 215/65x15. The 225 is a wee bit fate for the Jaguar 6" wide wheel but it'll be OK.
The V-rated tires have a stronger casing and stiffer sidewalls so downgrading means a softer feel to the steering, generally speaking. If you drive gently it won't matter much.
Don't compromise on weight rating, though. You want at least a 97 weight/load rating.
Old Nov 6, 2010 | 03:15 AM
wradford's Avatar
Default THanks
Very helpful. Thanks
MrWhite
19
Jun 14, 2022 07:49 PM
RedRider48
Oct 1, 2015 08:18 AM
XJ8JR
Sep 29, 2015 06:59 PM
42Ajd
Sep 26, 2015 07:04 PM
