Top hose replacement
Old Aug 17, 2019 | 05:37 PM
DannyRobertHoward's Avatar
Default Top hose replacement
Dear Friends, I am about to replace the top radiator hose as it has a pinhole that squirts coolant all over the under bonnet sound proofing material!
Do I need to drain the whole system before removal of the top hose?
As there is no radiator draintap, I suppose I need to remove the lower hose to drain?
Any advice will be very welcome.
Kindest regards, Danny.
Old Aug 17, 2019 | 06:23 PM
Doug's Avatar
No need to drain the entire system, no.
I'm guessing if you drain off about a gallon it'll be enough to prevent a big mess when the hose is removed
You might find a coolant drain tap on the underside of the transmission heat exchanger....which is on the lower radiator hose. Some had the drain, some didn't
Old Aug 17, 2019 | 06:29 PM
sanchez's Avatar
My 2 cents:
If the coolant level is low, you will lose very little when you remove the top hose.
Since there is a pinhole, the system should not be pressurized.
Remove the hose with the engine cold and you should have no problems.
Old Aug 18, 2019 | 02:36 AM
Hi Doug, I am very grateful for your help, I had an idea that there would not be a great deal of loss. Kindest regards, Danny.
Old Aug 18, 2019 | 02:37 AM
Dear Sanchez, thank you so much for your reply. Reassuring news. Kindest regards, Danny.
Old Sep 20, 2019 | 03:06 PM
afterburner1's Avatar
Doug
Can you tell me where the lower drain plug is on a 1993 coupe 6 cyl cooling system. I know there is one on the left side of the engine, but I'll be darned if I can find any other drain!
Shoreguy
Jun 13, 2018 07:49 AM
mcook
May 17, 2015 07:09 AM
ahunt4
Feb 1, 2015 08:53 AM
donberry
Jul 28, 2014 10:20 AM
