Transmission Case Hose & Connections
Old Dec 19, 2014 | 02:22 AM
ℬℒᏦ_ℙℕᏆℋℛ84's Avatar
Default Transmission Case Hose & Connections
Ok I've found the nipple on the transmission case that's supposed to attach to the rubber elbow hose underneath RH side but I can't find what type of hose connects to it , could this connection be the reason It won't reverse? I also found small drips comin from another tube & can't figure out where it connects to or what it is called to search it. Any help is appreciated, Thx
Bottom arrow is where drips are coming from
Old Dec 19, 2014 | 06:08 AM
Darrenmb's Avatar
Veteran: Navy
the black nipple is a vacuum on intake manifold, you have a vac leak, the other one is on the throttle body, neither of those have anything to do with transmission .
Old Dec 19, 2014 | 08:00 AM
Doug's Avatar
Right.
The transmission breather nipple is further back, on the transmission case.
As mentioned one of those nipples pictured is on the intake manifold and should either be capped or, more likely, have a vacuum hose attached to it.
The nipple on the throttle body could be for a vacuum hose, a breather hose, or a coolant hose. We'll need a better picture
Old Dec 19, 2014 | 12:45 PM
Default Vacuum/Coolant Drips
Hey what up fellas, I couldn't get a better pic it's a tight squeeze trying to get my Ipad in a good angle but I do think those drips could very well be coolant drips, not sure were it goes to yet
Also could someone post a pic of what the transmission breather look like & what/were it attaches to, I must be in the wrong section or overlooking it in the manuals.
aholbro1
Dec 29, 2024 06:46 PM
OkieTim
Sep 8, 2015 04:48 PM
1100me
Sep 7, 2015 06:26 AM
d a
Sep 3, 2015 02:34 AM
OkieTim
Sep 2, 2015 12:48 PM
