Transmission drain plug
Old Apr 2, 2015 | 09:48 AM
ahunt4's Avatar
Default Transmission drain plug
A couple questions, I've never done it before but where is the drain plug for the transmission? Where do I put new fluid in at after draining? Where is the starter relay located? What do I need to remove from the top and bottom to get to the starter? Finally, does just changing the brake pads on the rear require dropping lower suspension?
Old Apr 2, 2015 | 10:02 AM
NBCat's Avatar
It is always helpful when seeking advice on this forum to include the MY, engine type and other details about the vehicle in question.
There is also the search function to find topics that have been discussed quite often.
Old Apr 2, 2015 | 03:57 PM
ahunt4's Avatar
82 xj6 series 3 4.2 straight 6
Old Apr 2, 2015 | 06:47 PM
Saemetric's Avatar
No drain plug. Loosen the fill pipe nut and drain most fluid there. Remove pan and filter attached to valve body.
Starter relay on firewall, large silver one.
Starter can be removed from below
Rear pads can be removed with rear end in situ
aholbro1
Dec 29, 2024 06:46 PM
Jandreu
Jun 30, 2022 03:10 PM
Scarecrow
Mar 28, 2016 03:17 AM
chatmanx
Sep 11, 2015 07:17 PM
mrplow58
Sep 9, 2015 11:27 AM
