Antiback flow valve
It is in the trunk, in the spare tire well. Item #5 in this illustration.
Fuel Feed Pipes and Hoses-Trunk - Parts For Series III Saloon | Jaguar Heritage Parts UK
Remove it and blow thru. You should be able to blow thru it in only one direction.
Also how do you test a cold start injector?
Remove hose from the cold start injector. Remove injector from the inlet manifold. Re-attach hose.
Remove coil wire so engine won't start.
Have a helper crank the engine while you watch for fuel to spray out of the injector. Engine must be *cold*. It'll spray for only a couple seconds.
Be ready for a gush of fuel
