Antiback flow valve
Old Apr 2, 2015 | 09:57 AM
ahunt4's Avatar
Default Antiback flow valve
Where is this located on a 82 series 3? Want to see if it is closing and how would you do that? Also how do you test a cold start injector?
Old Apr 2, 2015 | 07:08 PM
Doug's Avatar
It is in the trunk, in the spare tire well. Item #5 in this illustration.
Fuel Feed Pipes and Hoses-Trunk - Parts For Series III Saloon | Jaguar Heritage Parts UK
Remove it and blow thru. You should be able to blow thru it in only one direction.
Remove hose from the cold start injector. Remove injector from the inlet manifold. Re-attach hose.
Remove coil wire so engine won't start.
Have a helper crank the engine while you watch for fuel to spray out of the injector. Engine must be *cold*. It'll spray for only a couple seconds.
Be ready for a gush of fuel
boiler
US Southwest
Dec 20, 2025 12:38 AM
vwbusbits
Oct 13, 2015 03:43 AM
Johncy2000
Oct 2, 2015 01:05 AM
jjmiah217
Sep 28, 2015 09:09 AM
