Transmission leak
Old Sep 16, 2017 | 09:14 AM
jordanmc's Avatar
Default Transmission leak
Hi everyone I have a very slight drip from what i am guessing to be the transmission oil pan. I have a new gasket so I figure I will start there. Do you refill through the yellow dipstick port? Should I use a specific transmission fluid?
thx in advance.
1979 jaguar xj6L series
Old Sep 16, 2017 | 09:38 AM
Doug's Avatar
Yes, refill via the dipstick tube
You [should] have a Borg Warner transmission. It's widely accepted that Type F of Type FA is the most appropriate fluid. The original specification was Type G as I recall....but that spec was made obsolete decades ago.
Old Sep 16, 2017 | 03:50 PM
new mexico's Avatar
thx in advance.
On my 78 xj I put a little red epoxy film on both sides of gasket, spread
out with finger, then tighten up very lightly.
Let dry over night before filling.
Put 4 quarts in through the filler tube and check the fluid when warm,
do not put more then shows 1/4" on the stick or it will leak out.
Walter
Old Sep 18, 2017 | 08:58 AM
JagCad's Avatar
A tip that might help.
Some folks think tighter is better on fastening tin to iron or alloy. Not so.
And it deforms the metal around the holes for the fasteners.
1. Result: Less effective clamping, voila leaks !
2. Fix. Use a small hammer and a backer. Tamp down the ridge around the hole ands restore a uniformly flat surface.
As a general practice, I apply a sealer only tot he part that comes off. And mostly for keeping a good quality gasket in place during the install.
Carl
Old Sep 19, 2017 | 08:54 AM
jordanmc's Avatar
Default Will this work
QUOTE=Doug;1760777]Yes, refill via the dipstick tube
DD[/QUOTE]
Old Sep 19, 2017 | 09:33 AM
Hi everyone I have a very slight drip from what i am guessing to be the transmission oil pan....
A bit of British wisdom I picked up recently:
"If there are no leaks, there's no fluid inside."
