trip computer
Old Oct 3, 2020 | 09:28 AM
robroy's Avatar
Default trip computer
I have a 87 xj6 (16 yrs now). The trip computer works fine, but when I turn the ignition off, it loses all programing...time etc. When I turn the ignition back on, I have to reset again. Any ideas for a cure??
Bob
Old Oct 3, 2020 | 09:40 AM
Doug's Avatar
It sounds like it is losing the constant 12 volt power supply. Check the fuses....which includes making sure the contacts are not corroded. The fuse you're after is probably #7 in the LH fuse box
Or......
Sometimes just disconnecting and reconnecting the wiring plugs at the TC will restore correct operation. Give it a try. If proper operation returns it suggests a poor connection at the plug-ins.
Or the TC itself might be failing. I had a slew of dead or partially dead TCs which I eventually tossed out. Across the automotive hobby we can see many examples of 80s-90s vintage electronics beginning to fail. Most commonly, solder joints on the circuit boards fail.
Old Oct 4, 2020 | 09:20 AM
robroy's Avatar
I also suspected loss of positive power when ignition is off. Do you happen to know which wire provides that power. Fuses all look good.
Thanks for the suggestions.
Bob
Old Oct 4, 2020 | 10:10 AM
Sparkplug's Avatar
I was pleased that my TC worked again after all the contacts were cleaned up.
This is what you need:
Jaguar XJ6 SIII trip computer details
Old Oct 4, 2020 | 11:07 AM
JagCad's Avatar
More:
Glass fuses may look good, but be open inside. Use a meter for continuity or a test lamp.
And, at times, merely rolling them in the cradle returns function.
Carl
robroy
Oct 3, 2020 09:31 AM
FastCat85
Sep 23, 2019 02:23 PM
rhminor
Dec 17, 2016 09:25 PM
Vee
Jul 20, 2013 03:12 PM
Scott Taylor
Dec 21, 2012 12:34 PM
