trunk light
Old May 11, 2012 | 11:01 AM
doghead08's Avatar
Default trunk light
can anyone tell me where if the trunk light fuse is inline and if it is where i may be able to locate it???
light used to work and i just noticed it has gone KAPUT. i dont have my haynes manuel in front of me and you guys are much more valuable than any manuel.
Old May 11, 2012 | 11:38 AM
Doug's Avatar
It's on the same fuse as your map light and interior pillar lights. If those are working, the fuse is OK. But, anyhow, it's one of the fuse in the left side under-dash fuse box....can't remember the exact number
Have you checked the wiring at the trunk light switch?
Old May 11, 2012 | 11:56 AM
Lancer-AM's Avatar
I haven't got this far into my survey of what is an isn't working on my car, but does the Ser II have a trunk light as well? It would be nice.
Old May 11, 2012 | 01:16 PM
doghead08's Avatar
my map and interiors both work. where is that switch located???or am i looking at the wiring connected to the light itself ?
Old May 13, 2012 | 09:27 PM
doghead08's Avatar
Problem solved..i think. I unscrewed the light and cleaned all the connections etc. That wasn't the issue. I found that the one of the wires have a weak connection to the button/switch. The wired are soldered in and one is pretty loose. I used some electrical tape for now but will fix the right way during the week.
mbergen
Oct 23, 2019 10:26 PM
martybmw
Apr 2, 2016 04:55 AM
XJsc-guy
Nov 23, 2015 01:56 PM
prettydaim
Sep 7, 2015 05:16 PM
02jagstype
Sep 4, 2015 08:20 PM
